suburban air conditioning... r-12...r-134??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Apr 29, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i know i have r-12 now, would it be worth it to switch to r-134a? that and how much r-134a would my suburban need? i have front and rear air.
    ps: living in 'vegas, I NEED AIR CONDITIONING SOON!!!!!
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Keep your r-12. I have the r-134 and it is no where as cold as the r-12.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    In your place, I would also take R12. With R134a the achievement of the plant doesn’t only sink. You need new seals, a new dryer and connecting piece for the change. The R134a must be renewed every three years, because it evaporates by all lines (diffusion). And the compressor is more badly lubricated. But unfortunately R12 is forbidden in Germany.
    You need little more than 6 lbs.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    My 87 Suburban with front and rear air take 5.25 lbs of r-12. Stick with r12. Pay the extra money for it and you will be happy. r134 just doesnt cool near as well. r134 also runs at higher pressures than r12, so parts wear out quicker ie compressor.
    Dan
  5. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    make sure your system is up to par and go with R12.. 134a does a good job in a system designed for it, but even then I prefer R12. Except the stuff is expensive. I have 3 12oz cans of R12 staring me in the eyes right now, I cant wait to put it in my truck..
    mike
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    Well I'm taking the other side here. I forked out almost $200 for a charge about 3 years ago. That didn't even last me 2 summers. That is unacceptable in my book. Even after the system no longer worked, the shop was unable to find any significant leak. I want to do the service and maintainance myself and I don't want to get certified just to buy a huge tank that costs $500.
    So last spring I converted to R-134. Every new drier is compatible and they are relatively cheap. You just need to flush the lines and replace the O-rings. Then you need a vacuum source to remove all air and moisture (the low pressure of the vacuum makes water boil at room temperature).
    Does it cool as well as R-12? no. Does it cool better than the system that is low on R-12 and has to be professionally serviced? Of course.
    But there are some things you can do to make up for the loss in efficiency:
    -Use a VOV. These valves give you a little better cooling at idle compared to a stock orifice tube and extend compressor life.
    -Switch to electric fans. You notice the loss of cooling the most at idle because the stock fan is not moving enough air. Electrics can provide full flow regardless of engine speed. Adding a booster "pusher" fan or two on the front of the condensor also helps. You can cycle them with a relay along with the compressor clutch. They need to be high flow, though.
    -Use an adjustable clutch cycling switch. This adjusts the cutoff pressure on the low side. You're in luck. Your system probably already has one.
    All of the money I spent on the conversion and upgrades was less than the cost of one charge of R-12, which I would lose before too many years anyway. The performance is now rougly equivalent to a stock R-12 system
    I don't know anything about the rear A/C units, but having both front and rear will let you tolerate the loss of cooling capacity much easier.
  7. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I used propane.
    That's right, I said propane.
    Ever hear of R-12a? It was an R-12 substitute that came out a couple of years ago. It was just propane in a 12 oz. can.
    I also agree that R-12 is better than 134a, but you just can't get it anymore, and if you do find some, it's probably mixed.
    After talking with several mechanics and tractor places, I decided to try propane in my '81. It was getting low, but it still had some R-12 in it.
    I know of several guys who have nothing but propane in their truck's A/C system.
    I do RV A/C work which uses R-22, so I had all the equipment necessary. I rigged up a way to get propane out of my 20 lb. bottle and into my truck's A/C system. I tell you what, this thing is blowing colder than it ever has!
    WARNING: attempt at your own risk. Obviously LP is much more flammable than R-12, but it does work very, very well as a refrigerant. If it leaks, you might have a fire hazard, especially if it blows all at once.
    In my mind, it's not anyworse than having gasoline and electricity flowing together underneath the hood (or diesel, in my case).
    Good luck.
    Casey
  8. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    I have heard of this. Never talked to anyone that uses it though.. I heard its GREAT as a refrigerant, it was just dropped due to its safety hazard. I really like this idea, did you use the recommended amount & type of oil for R12?
    as for R12, it cost me $20 to get certified and I can buy it at pep boys, kragen, etc when I need it. (or I can buy it in large quantities)
    What I really want is the manifold & guages to do R12 work. something that I can connect a vacuum pump too also. Ive looked around but to no avail.
    mike
  9. arveetek
    Mar 1, 2002
    722
    Since I added the LP to just a low-charge system and not an empty system, I didn't add any oil.
    My K-10 is next on the list. It's completely empty, and I don't know if there's anything majorly wrong with the system or not. It's all there, but it wasn't working when I bought it. I plan to vacuum it down, and add some oil to it, and charge it back up with propane.
    Casey
  10. GMMANIAC
    GMMANIAC Registered Member
    May 1, 2002
    53
    San Antonio, Tx.
    Switch to R134. With a few minor mods you can make the system cool better than the R12. I converted a friends Sub and I also did my Blazer. One thing that works real well is a self adjusting orfice tube filter. You should also install an electric cooling fan. I install the fans with a relay that runs off a Mercedes high pressure switch installed in a fitting that you attatch to the condensor.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I worked with a guy about 15 years ago that had done the conversion to propane. But he had done some research and found that a certain mixture of propane and butane actually produced the coldest output. He called it his "propain" conversion. /forums/images/icons/wink.gif
  12. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Did the switch on my Sub, it has front/rear A/C and I haven't noticed any difference in cooling, when one considers that you're trying to cool a football stadium in volume....its doing just fine.
    White Knight
    Christian/republican/redneck three of the best things in life
  13. arveetek
    Mar 1, 2002
    722
    I've been driving around for about a week now with my K-10 fully charged with 100% propane. It's working great and blowing cold! I vacuumed the system down, added some R-12 oil, and then charged it up with LP. So far so good!
    My compressor is making some odd noises, it almost sounds like a turbo, with a whine that corresponds to engine rpm. Hope it's not about to go out.
    Casey
