SUBURBAN ARE THEY WORTH LIFTIN 10 INCHS OR TO HARD TO DRIVE
Discussion in 'The Garage' started by B'hamK5, Jun 26, 2004.
  1. B'hamK5
    B'hamK5 Registered Member
    Apr 5, 2003
    13
    HELP ME OUT
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    IMO nothing needs to be lifted that high.
    Do a search.
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Nobody really needs that much lift. GM front driveshafts are very short to begin with and won't handle that much angle unless it's a custom unit. You'll have much better luck with a 4"-6" lift. And no, your 10 bolt axles will not hold up to anything larger than a 35" tire. Stock tires are even pushing it with the weight of a Suburban. Good luck with the searching though, there's lots of other posts about this topic already. /forums/images/graemlins/thumb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It can be done, but it's alot of $$$ to do it right. First off, that much lift is going to mean some big tires. Might as well start looking for some 1-ton axles, cause those 10bolts won't last, and it'd be foolish to regear them when they will break anyways. In all honesty, to get the 10 inch, I'd go 6" suspension lift, + zero rates on both ends, and a 3" body lift. Next call up Jess at High Angle Driveline and have him build you some CV shafts. Lets not forget the crossover steering. That's just a few things too think about.
  5. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Your a discrace /forums/images/graemlins/angryfire.gif
  6. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
  7. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Good link there Jacob. /forums/images/graemlins/waytogo.gif
  8. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    uhmm, I believe it's $25. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif and good search, glad someone has luck with it /forums/images/graemlins/thumb.gif
