Suburban axels to K5
Discussion in 'The Garage' started by mrcold, Aug 3, 2004.
  1. mrcold
    mrcold Registered Member
    Jun 6, 2004
    37
    North of SWEDEN
    What do I have to do to get axels from a -70 suburban to fit my -86 K5? Is there any difference in length or something else I need to know?
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    It's a direct swap
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    What year exactly is the Suburban? Like Bullet said, if it is a 1973 or newer, it is a direct swap. 1972 or older is not. /forums/images/graemlins/waytogo.gif
  4. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    It’s a 1970 suburban
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    rear spring spacing is different so the rear perches need to be moved to match the k5's spacing. the front is a direct bolt in. Is the front drum brake /forums/images/graemlins/eek.gif
  6. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Nope the front is disc. What about the length of the axels, are they the same?
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yep /forums/images/graemlins/waytogo.gif
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    same castings. width too /forums/images/graemlins/peace.gif
  9. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Ok thanks! I would have to pay 1050 $ for the front and rear axel with 4.57 gear ratio, is that a reasonable price?
  10. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Here in the States, that's waaay too expensive. Seeing as there are prolly many less Chevy trucks where you are, that might be okay.
    You will need to cut & re-weld the spring perches, so it's not a drop-in affair. If you can weld or know a welder, this is fine; otherwise, you might wait to get a 1973-1991 set of axles.
    -- A
  11. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Well how much would you pay? I have been looking for a set of axels the howl summer... /forums/images/graemlins/frown.gif and these are the first ones with the right gear ratio that has popped up. I can weld them my self so that’s no problem. /forums/images/graemlins/peace.gif
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    depending on bearing condition and brakes i would say $400-$500 is average here for a pair.
  13. mattcorleone
    mattcorleone Registered Member
    Jun 30, 2004
    18
    Bangor, ME
    As an example... I've been looking for three weeks now and have come across a pair of 3/4 ton (14 bolt & 10 bolt w/ 8 lugs w/ 4.11's and a locker out back) that had virtually brand new 6" lift springs, shocks, and steering arm all bolted onto it for $700. I also found two other 4.56 14 bolts for $100 - $125. I don't know condition as I have not gone to look at them. Like you, I am looking for a matching front and rear set w/ 4.56's... something that is kinda hard to find. You could try to negotiate some... but if it's what you need it's what you need. You could probably easily find a pair with the incorrect ratio and regear it for less than what they are asking... but I don't know how nice they are or how much work you want to put into getting them ready to put in... or how many junk trucks are around you that you could get axles out of.
  14. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Ok… maybe I can get them down 150 – 200 bucks to $900 ore so but I don’t think I can get them much cheaper here in [darn] Sweden! /forums/images/graemlins/angryfire.gif Well at least they have the right gear ratio! I can probably get the $900 from selling my current axels and the tiers and rims! /forums/images/graemlins/smile.gif
  15. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Well every thing that has something to do with American cars is [darn] expensive here in Sweden. I don’t think it will be cheaper to regear them as a set of ring and pinion cost like $300 new per set and $150 - $200 used in good condition.
    The ones I have found have a locker rear and front if I remember correctly and are 8 luge.
