suburban dome light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OldBlew, Mar 17, 2002.
  1. OldBlew
    OldBlew Registered Member
    Mar 10, 2002
    28
    Girdwood, Alaska
    Ok you guys, before you yell at me, I did do a search.......
    I've replaced all my door switches and the headlame switch. The dome lights come on when I hit a bump or something. Then they will be OK for a while, and work fine. Then I start blowing fuses!
    I must have a short but I cant find it. Can anyone tell me where the wires are?
  2. dyeager535
    26,980
    I would have to venture a guess that they are either between the roof panels, or run under the carpet near the doors. I believe my dads K20 runs them under the carpet, then up the rear cab "pillar".
  3. I looked in the factory repair manual for a 90' Sub, and it shows it runs down the left front door sill,up the door frame and over to the dome light, the same circuit continues down the frame back along the rear door sill and up the rear door latch frame. From the top of the frame the harness goes to the rear cargo lamp.
    Hope this helps.
  4. OldBlew
    Mar 10, 2002
    28
    Girdwood, Alaska
    Thanks,
    I've been out of the site for a couple of days.
    I've been in the middle of college finals.
    Hopefully, I'll have a little time soon to fix it.
