suburban front axels
Discussion in 'The Garage' started by bleedchevy, Sep 28, 2004.
  1. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    did one ton suburbans have d60 for front end or d44? cause i ran across one for sale with a 454 that still runs.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    There were no 1 Ton Subs. 3/4 ton's had D44's or 10 bolts /forums/images/graemlins/waytogo.gif
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yepp 1 ton subs dont exist in stock form, there were only 1/2 and 3/4 tons and the and both had 10Bs or D44s under them, some 3/4s were 8-lug though but still a 10 bolt.
  4. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    woah, its a suburban with 1 tons, not a 1 ton suburban, i had someone more knowledgable look at it then my friend.
  5. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Not positive, but I don't know of any old Subs that came with a 454.(Not '69-'91) BUT THAT MAY NOT BE TRUE; I would check the VIN on the block,and crawl under the front and take a look at the axle. /forums/images/graemlins/thinking.gif
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    How about some more info on the burb so we can help more. I also agree that there was no option for a 454 in a 4wd burb. If it's a D60 front than it was swapped in, also make sure it is in fact a D60, a d44 and 60 look somewhat the same without standing in front of them.
  7. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    im about 500 miles away from it, and from what i been told recently that the motor was transplanted, as well as the 1 ton running gear, i was mainly wondering what came in the 3/4 ton suburbans, not knowing if the 454 was an option or not, as well as what the running gear. you guys are great help in getting my facts straight. /forums/images/graemlins/bow.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you are making sur eit is a D60 front, then have your friend check and see if the steering arm on the driver side bolts on with 3 or 4 nuts... D60 king pins have 4 studs on the top and on the bottom.... The D44's will have a slightly curved steering arm with 3 studs/nuts holding it on...
    On the 454 thing, I am not sure.
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I thought you could get a 454 in a burb 3/4 ton. A guy I work with has an 89 2500 with a 454 TBI /forums/images/graemlins/dunno.gif
    Just looked on KBB and it's an option /forums/images/graemlins/thinking.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can get a 454 in a 2wd 2500 burb in '89.
    No 4x4s until 1992.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    No 4x4s until 1992.
    [/ QUOTE ]Bingo. Somehow GM thought the front IFS could handle more power than a good 'ol D44 or 10B. /forums/images/graemlins/screwy.gif
