suburban fuel tank into a shortbed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike reeh, Jan 27, 2002.
  1. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    We scrapped a wrecked 79 burb with the big rear tank, and I cut that section of the frame out with the crossmembers and straps hoping to put the tank into my shortbed frame... Ive heard of this on longbed trucks but it looks like I Just dont have the real estate for that big tank on the shorter frame. It should would be awesome to have three tanks. I wont be running a spare down there anyways..
    thoughts? ideas?
    mike
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have a LWB picjup and plan on putting a K5 tank up front behind the cab between the frame rails. I think with a few crossmembers and a few strraps it should work well. I dont think you could jam it between the rear ones though. I havent really got under mine and looked, so I may be a bit off. Anyway, good luck.
    1978 K20 - 355ci, np205, th400, D44, 14F, 7" of Lift, 36 x 14.5 TSL Radial
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Mike AGM73K5 put a 40 gallon tank out of a burb in his 73.
    Ya might PM him to see what he did to make it work.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    DOH you have a pickup. never mind.
    I can carry 55 gallons in the 73 with both tanks.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I remember someone with a shortbed and Blazer/Sub tank, but I don't know who it was. I do know they had taken off the bed and it was sticking up above the frame rails instead of down. Whoever it was posted pics to CK5 or ORC, it's been a long time and I don't remember anything else about it.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
