Suburban GVW ???
Discussion in 'The Garage' started by jesterdzs, Jun 30, 2006.
  1. jesterdzs
    jesterdzs Registered Member
    Jul 7, 2005
    56
    Silverspring , Maryland
    what does a 91 3/4 ton 4 burban weigh ???
    trying to find a bolt on tow bar to drag it to kansas from maryland
    and i cant read the #s on my sticker to faded:confused:
  2. goldwing2000
    goldwing2000 Guest
    The sticker won't give you curb weight, anyway. It will only give you GVWR, which is the weight rating of the vehicle (curb weight plus max cargo).
    If I had to venture a guess, I'd say around 5,000-5,500 for a stock 'Burb. If it's not stock, then you're gonna hafta get it weighed. Most truck stops will weight it for under $10. Sometimes less if you don't want an actual printout.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My '84 C20 (2wd) Burb w/6.2L diesel is 6000#.
  4. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    You might want to reconsider flat towing something that heavy. Most states require trailer brakes for over 3500 lbs, and in this case the 'burb would be considered a trailer. I'd look at using a dolly with brakes or a car trailer...
    I flat towed a somewhat stripped '82 Blazer from TX to BC (2500 miles) behind my '81 Jimmy about 5 years ago. I had to run it through scales after crossing into Canada and it came in at 3370 lbs as it was. Even being that light it did a fine job pushing the back of my truck around through corners and stuff. On wet pavement I almost wrecked on a freeway on-ramp once.
    What were you planning on towing it with?
    Rene
  5. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    GVWR form the '91 V2500 'Burb in my driveway is 8600, right off of the door.
  6. goldwing2000
    goldwing2000 Guest
    He doesn't want the GVWR, he wants the curb weight.
  7. jesterdzs
    Jul 7, 2005
    56
    towing with a 26ft international box truck (penske)
