suburban questions
Discussion in 'The Garage' started by pismorat, Feb 25, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    My dad is looking at a 1999 Suburban with a 6.5L turbo diesel. He thinks it has a 4L80E tranny and a 245 transfer case. It has a Superlift 6" lift, 35" tires, 16.5" weld wheels, and 4.10 gears. It has 55,000 miles on it. They are asking $22,000. Is this a good deal? What rear axle would this have in it (Dana 60)? Limited slip? What is the max towing capacity? Could it easily tow a weekend warrior with a car inside? Is this a good vehicle for all around use + towing? What are you opinions and thoughts?? Thanks a lot. /forums/images/graemlins/burb.gif
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Yes it will be a 4L80E and an NP246 (I think). If it came factory with 4.10s it must be a 2500. That would = a 14 Bolt FF. This would make a great towing vehicle, around 10,000 would be about the max.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Some were rated to 12,000 lbs., but it depends which options were checked off when it was ordered.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Only problem I can forsee is the auto-trac transfer case... I've heard rumors the vehicles with the auto-trac weren't "liftable" for whatever reason... may have to do with the traction control and larger tires - dunno for sure.
    If it packs it in, just swap in a BW4401 or 4470 /forums/images/graemlins/thumb.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    he already said it has a 6" lift.
  6. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    They are "liftable" you just have to make sure you get the correct kit- our 99 Z-71 which had auto trac had a Rancho 4" lift...(okay okay the lift never made it out of the box and onto the truck......but rancho makes one) Superlift makes one- and I believe pro-comp.
    The guy I bought my K5 from just had a hassle with Skyjacker- they sent him the wrong kit twice- for his 99 Tahoe with the auto-trac....he ended up going rancho.
    Brandy
