suburban questions
Discussion in '1936-Present Suburban' started by pismorat, Feb 25, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    My dad is looking at a 1999 Suburban with a 6.5L turbo diesel. He thinks it has a 4L80E tranny and a 245 transfer case. It has a Superlift 6" lift, 35" tires, 16.5" weld wheels, and 4.10 gears. It has 55,000 miles on it. They are asking $22,000. Is this a good deal? What rear axle would this have in it (Dana 60)? Limited slip? What is the max towing capacity? Could it easily tow a weekend warrior with a car inside? Is this a good vehicle for all around use + towing? What are you opinions and thoughts?? Thanks a lot. /forums/images/graemlins/burb.gif
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I'm not likely to be much help, as I'm more in on the older suburbans. equipment options depend on wether the truck was originaly a 1500 or a 2500. if it were originaly a 1500, then transmission is a 4l60e. if its a 2500, then its more likely the 4l80e. the rear also depends on the weight class. if its a 1/2 ton ( 1500) its probably just a 10 bolt rear. if its a 3/4 ton, then chances are its a 14 bolt semi floater, or a 14 bolt full floater ( do they still make those?) easiest way to tell is to count the number of bolts holding the rear differential cover on, and the number of lugs on the rim. I don't believe chevy uses D60's in the rear ends of its trucks, since it has the 14 bolt instead, although who knows.
    maximum towing capacity is more likely then not dicated by wether its a 1/2 or 3/4 ton truck, and chances are, its just the standard 11,000 Lbs CURB weight. this means Truck+ trailer weight. most people believe 11,000 Lbs means you can hook up an 11,000 Lbs trailer to it, and take off, and most manufacturers don't really do much to clarify this while they're advertising. what you need to do is take the truck weight ( say 6500 Lbs GVWR) and subtract it from the towing capacity, meaning you can safely tow about 4500 Lbs behind it.
    as for wether it can haul a massive trailer behind it? probably not safely, especialy on 35's, but it'll most likely have enough physical power to do it.
    22,000 for a 4 year old truck? I don't think I'd go for that, but then again, I'm also part of the `built not bought' crew, and have only spent 2500 bucks to date on `burbanzilla' ( 73 K20 suburban)including the 454 that I'm building up to drop in it.
    someone chime in and correct any/all my misconceptions...
    -Rich
  3. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    If it came stock with the 6.5 it's either a 1500HD (not many around) or more likely a 3/4ton. I'm pretty sure the only tranny you could get with the 6.5 in a suburban was the 4l80e. Personally I think $22,000 is a bit pricey. I'm not much into the post '91 suburbans anyways. Sorry I'm not much help, I'm sure someone here will give you the info you need.
    Jon
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Your paying for the lift/tires/rims etc....around here, you can pick up a 99 2500 with the 454 for under 19K......with less miles that that.....
    bonus of the 99 is it's not the 'new' body style
  5. rtigert
    rtigert Registered Member
    Feb 16, 2003
    14
    Gainesville, Texas
    I can buy a '99, 3/4, 454, 4X4 with leather, 65,000 miles, and wheels/tires locally for $16,000; so I think that the price is...well, "pricey". As far as the rear on a 3/4 late model, it will have a semi-floating 14 bolt.
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The later model 3/4 ton with turbo deisel probably has a 14bff rear, and may have a factory traction device.
