Suburban Rear Axle Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaBnn3, Sep 4, 2005.
  1. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    I'm on my third rear axle for my 1988 V10 Suburban, and it's time for a rebuild or replacement. I'm wondering if the axle for a 3/4 ton model will bolt right in and solve my axle turnover problem. I go four wheeling, but nothing crazy. There's no particular reason why these keep blowing on me.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    A 3/4 ton axle is a direct swap into your 1/2 ton burb. What exactly do you mean by "turnover problem"?
    Just make sure that whatever axle you swap into your burb has the same gear ratio as your front axle or you will break your t-case.
  3. GaBnn3
    Jan 2, 2005
    90
    Holyoke, Ma.
    I meant that I keep going through axles. I wasn't referring to a mechanical issue. Thanks.
  4. utchev
    utchev Registered Member
    Aug 17, 2004
    91
    Salt Lake City.....
    Find a 6 lug, semi-float 14 bolt or you could just swap both axles from an 8 lug donor truck.
