Suburban rear ends
Discussion in 'The Garage' started by stockk5, Sep 27, 2004.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    What rear ends did 80-85 suburbans have. Im sorry if this is a broad question but there is a junked up one at a neighbors house that has been sitting forever. I was gonna offer them some $ for it if it had any good parts. I have 10bolts right now and looking for cheap upgrades. Thanks Mike
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    If it was a 1/2 ton it should be a 10 bolt. A 3/4 ton could have the semi-floating 14 bolt or a full floating 14 bolt.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You can use the rear-end out of any 1/2 or 3/4 ton 73-87 pickup. The half tons will be 10 bolts (some 12 bolts in the earlier years). The 3/4 tons will be 14 bolt FF (and some 14 bolt SF in the later years). You can even use the rear axle out of a 1 ton which will be a 14 bolt FF, but you have to relocate the spring perches.
    What I'm trying to say is that there are a lot of options out there. You don't need an axle out of a suburban to put under your suburban. Just match the ratio of the front axle and go!
    And, as far as "cheap"...you shouldn't have to pay more than about $200 for any of the axles I listed above (unless the axle has an aftermarket locker or limited slip...then it might be more expensive).
  4. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    My 86 'burb's got a 12 bolt under it /forums/images/graemlins/dunno.gif but maybe this link will help CK5 Axle Guide So just go look and see /forums/images/graemlins/smile.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    either its a transplant or a 14 bolt semi floater. 1/2 ton or 3/4 ton brb? 14 bolt semi floaters and 12 bolts look very similar pumpkin wise.
