Suburban seats in a crewcab?
Discussion in 'The Garage' started by k204dr, Oct 3, 2006.
  1. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    so, will 87 suburban front buckets bolt into my 88 crewcab easily, other than drilling more holes for the inner bolts? looking for something a little more comfortable and adjustable than the vinyl bench I currently have. the junkyard has a suburban with buckets, probably gonna take a look at them thursday.
    I'm assuming these seats are fairly comfortable, anyone? thanks.
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    frts bolt in basicly rear? dont know my self.
    you will need the frt inner support brackets that are spot welded to the floor pan.
  3. k204dr
    Aug 27, 2004
    463
    TN
    dang I need to buy membership, gettin tired of not seeing pics. what do you mean by rear? I'm trying to put them in the front. so theres a bracket spotwelded into the suburban floor if it had buckets? i'll have to bring a drill I guess.
  4. MagnuM4WD
    MagnuM4WD 1/2 ton status
    Jul 26, 2006
    138
    Bucureşti - România
    It is... a kind of... Each bucket have 4 points on floor, where they mounting with screws. 3 of them, are holes, with nuts welded under the floor, but the 4-th, have a kind of bracket, welded on floor, with nut welded inside of the bracket.
    I have buckets, in my truck and I make some pictures, inside, with empty floor. Look to the image oo9, 012 and 018, to make your own ideea. In pictures, you can se the holes and the bracket. Good luck! :waytogo:
    http://s113.photobucket.com/albums/n221/MagnuM4WD/My%20Suburban/?start=20
  5. k204dr
    Aug 27, 2004
    463
    TN
    sweet, thanks for the pics. that helps.
    Romania huh? had no idea they had suburbans over there. did you have to fix some rusty quarters?
  6. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    Yes, I must make some "repairs", to the body panels and LH front frame (steering gear area).:(
