Sucked up some bad gas, what to do??(updated)
Discussion in 'The Garage' started by TrcksR4ME, Jun 23, 2003.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    My truck had been parked a while and I moved it around now and then to keep everything working, but the gas got pretty low so I put in some gas for the lawn mower before going to the gas station.
    Well it ran fine until the next day, then it wouldn't idle. Changed the fuel filter but still won't idle and looked at it again(see through) and it was dirty again.
    (update)....................................
    SO it seems to be running better, I made it run for a while in the driveway at about 1200 rpm and it seem to get through the bad gas. I changed the filter again, and I still see some crap in there, but I'll see how it does for now.
    This was weird though cause my truck has been sitting a lot off and on for 5 years and I never had this problem before. It is really sensitive to gas brands, as in ARCO need not apply /forums/images/graemlins/tongue.gif
    Thanks for the help and ideas!
  2. dyeager535
    26,980
    Re: Sucked up some bad gas, what to do??
    If it were me, I'd probably fill it up with good gas, and take it for a drive. Will mix all the gas (bad and good) together, and if its only one gallon of bad gas, you won't notice it.
    The "sock" in the tank should be preventing a lot of garbage from getting to your filter, are you talking just small stuff, or pretty large chunks?
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    looked like mostly small particles. I put about half a tank of gas in before it started acting up so hopefully anytime it will start running a little better.
    I ran it for about 15 minutes at about 1200 rpm, and the filter looks like its collapsing in on itself, and the fuel level in the filter was only at about 1/3 (Spectre see through filter). It also looks like there was moisture or something in the filter, looked like condensation on the glass... /forums/images/graemlins/frown.gif
    I dunno, story of my truck, runs fine one day, the next ... /forums/images/graemlins/confused.gif
  4. dyeager535
    26,980
    Well the sock in the tank is supposed to prevent water from leaving the tank, but after this many years, who knows. They *do* wear out.
  5. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i'm with DYEAGER535 get some good gas and drive it. my truck sits alot to ,it's runs but no lights right now,i'm painting it. it took 2 yrs. to get it drivable and damn that gas is like varnish.every friggin' year it's the same.but after the new gas she pures like a kitten, and stinks frow the old gas. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    Fill her up w/ Ethyl. If Ethyl isn't available, take her sister w/ you.
    Fill it up w/ "branded" gas(ie. Shell, Exxon, etc) and add a pint of B-12 Chemtool or the like in order to help "dry out" the bad fuel.
    Good Luck
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I'll give it a try once it will idle well enough to drive, think it might now. Since I have an auto, it makes it hard to drive it around when it won't idle.
    Also might check out the fuel pump if problems persist, have to pull it anyways cause it has an oil leak.
