Sudden - No Start
Discussion in '1982-Present GM Diesel' started by Terry, Apr 17, 2002.
  1. Terry
    Terry Registered Member
    Feb 21, 2002
    12
    No. Michigan
    My 6.2 suddenly decided not to start, luckily in my driveway.
    Ran & started perfectly since new GP's about a month & 1/2 ago. Than today - cranks fine but no start.
    GP' cycle OK.
    I'm not getting the smoke from the tail pipe I'd normally get when I turn it over. Could this mean injector pump?
    It was the first attemped start this morning after sitting all night. Ran fine last night.
    Any help is appreciated.
    TNX in advance.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It definitely sounds like a fuel delivery problem. I'd start by cracking an injector line and seeing if you get any fuel out of it. It could also be a clogged fuel filter. Generally when injection pump fails it leaks out of the throttle shaft. I don't think I've ever heard of a pump failing out of the blue like that.....
  3. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Check for a loose wire (pink?) on the injector pump too.
  4. Can Can
    15,552
    136
    Yup, it could be that pesky pink wire as well........./forums/images/icons/wink.gif
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    If none of that works check your fuel pump, the one on the side of the engine.
  6. Terry
    Feb 21, 2002
    12
    No. Michigan
    If I'm looking under the hood, where is the injector pump/pink wire located?
    I've got a 91 chev pu with the 6.2
  7. Can Can
    15,552
    136
    The injection pump is located towards the front of the block in the middle, just in front and below the air cleaner housing. The pink wire connects to the pump on the top passenger side of the pump.......
  8. CustomCruiser
    CustomCruiser Registered Member
    Jan 10, 2002
    12
    Texas
    I had the same problem in my driveway. Turned out to be the ground strap at the rear of the engine. Sure did run better with a filter and other new stuff bought out of desperation.
  9. Terry
    Feb 21, 2002
    12
    No. Michigan
    Turned out to be the fuel pump. Replaced it and it starts & runs fine.
  10. Can Can
    15,552
    136
    Good to hear, brother!!/forums/images/icons/smile.gif
