Suden Oil leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JayHornyak, Jan 22, 2003.
  1. JayHornyak
    JayHornyak Registered Member
    Feb 15, 2001
    18
    Clinton Connecticut
    Hey does this make any sence? It got really cold, IN the teens and low tweenty's plus wind chill, and all of the sudden I started leaking oil. My truck does not usually leak much of any thing. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    First of all, what is the fluid...is it engine oil? And, where is it coming from? Where's the puddle developing? It may not have anything to do with the cold, then again, it could. We need more info though.
  3. JayHornyak
    Feb 15, 2001
    18
    Clinton Connecticut
    Definatly engine oil. Can't see where it is coming from other then the rear of the block modt of the drips seem to be on the front drive shaft starter area. /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    Hmmm...in order to get it on the starter/that area, I'm going to have to say check the valve cover. The gasket might have blown out near the rear of the cover. Possibly got too cold and brittle and crumbled to pieces /forums/images/graemlins/confused.gif. That's my first guess. I'm sure there are other opinions out there, but this is probably the easiest/cheapest to fix. Good luck.
    By the way...is it a constant drip, or more of just a small puddle after parked for a while? Does the drip get faster/more frequent while the engine is on?
  5. JayHornyak
    Feb 15, 2001
    18
    Clinton Connecticut
    NOt sure how constant it is just found it today. Noticed a small spot in my brand new garage earlier then noticed it dripping while running as I picked up my son from day care. /forums/images/graemlins/1zhelp.gif
  6. heavy4x4
    Aug 28, 2002
    3,270
    Well, I'm out of ideas...I'm going to stick with valve covers leaking. OOH, or maybe the rear seal of the intake manifold too. Give both of those a check. Others, feel free to ring in.
  7. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i think heavy4x4 is on the right track. i had a bad PCV valve (positive crankcase ventaltion) it sits on the drivers side valve cover. if its stuck the crankcase will develop enough pressure that in my situation blew out a chunk of the valve cover gasket right over my starter.
    do you have a mechanical oil gauge? my poly line melted one day and tossed oil all over the place. /forums/images/graemlins/grin.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    OOH, yeah, there's an idea. Maybe the PCV froze up. Pull it out (located on the passenger side valve cover towards the front of the engine) and give it a shake. You should hear it rattle. If it DOES NOT rattle, go buy a new one for $3. That still won't solve the oil leak, though. It'll just prevent it from happening again once you replace the valve cover gasket /forums/images/graemlins/grin.gif
