suface rust removal
Discussion in 'The Garage' started by ryan22re, Mar 25, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    what would be the best way to remove surface rust on machined parts?
    tryed some penetrating oil added some elbow grease and scotchbrite pads, looks ok, but need to get more off.
    was thinking naval jelly? or soaking in some kind of oil.
    what do you use?
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    If I'm planning on painting them, I use the brush-on rust treatment that bonds with the rust and turns it into usable primer.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Turpentine is a good surface rust remover. Srub it on with some steel wool. Let it sit for a bit, and scrub some more.
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Phosphoric acid in one of its many forms (liquid.. sometimes called "Ospho", and the gel form known as naval jelly) helps neutralize and kill rust. Just be sure to rinse and whipe it off thoroughly.
    If the surface is already pitted, you wont be able to get that 'machined surface' back without removing more steel (re-machining it).
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    FLITZ!!!!:haha: :haha: :haha: :haha:
