suggestion on shock measuring and mounting
Discussion in 'The Garage' started by readymix, Jan 15, 2005.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    On the front, i have the quad shock setup. I am going to get the ford towers and mount them. Will the stock hanger on the D60 be in a good location? or should i weld on a new set in a differnet location
    On the rear. I plan on moving the shock mounts to the top of the axle tube and building a crossmember to mount the upper shock to. Like what is seen on MOO.
    Where can i get the shock mounts for the axle?
    What direction should the shock bolts go. Left/Right - or - Fwd/Back? Looking for the rear and front axle.
    Here is the kicker. I don't have an RTI ramp in my pocket or access to anythning like that. If i try to use a loading ramp on the base they will surely have my A$$ in chains.:) Is there any other trick for measuring that i have not thought of.
  2. readymix
    May 30, 2004
    6,706
    26
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You could use an engine hoist to lift a corner of the truck.:)
  4. readymix
    May 30, 2004
    6,706
    26
    The only thing i have that could lift one corner of teh truck would be my floor jack. Don't think it will get high enough.
    I might just go buy a Hi-Lift jack and run a strap through the rim to lift it. It should go high enough but might not.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm lucky enough to know a farmer with a forklift :) As for the direction of the bolts and shock mounts, most people I've seen running Ford towers run the factory lower shock mount. Also, on the rear axle, all of the setups I've seen have the bolts running forward and back. If you think about the way the axle moves when your suspension cycles, it makes sense.
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  7. readymix
    May 30, 2004
    6,706
    26
    I saw that a long time ago...but had completly forgotten about it until now. I found the old stamped steel ones local for $11.75 ea. I will have to call the dealership back on monday and get a quote for these.
    Thanks for the info.
    Do you think they will put the shocks too close to the steering shaft or am i just looking at my truck wrong?
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    You can put the towers any way you want. I moved mine around to keep them as close to the same angle as the stock shocks were and they don't have any issues with the steering shaft.
