Suggestions on 700r4 pump?
Discussion in 'The Garage' started by mr.smartass, Sep 18, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    getting my 700r4 rebuilt, just wondering what pump to go with and who to order it from... any suggestions?
  2. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    nothing? i hear get a 10 vain pump... just don't know to much about them.
  3. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
  4. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    I believe the stock pump is 19 vane so not really an upgrade there, ask a local tranny shop they will help you choose a pump. Ebay has alot of upgrades for trannys.
  5. 6.2puller
    Jul 8, 2004
    569
    New England
    Stock is 10 I am pretty sure.
  6. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    7, 10, and 13 vane pumps all came stock in different years. If you have a 7 upgrade to a 10 or 13. Mine came with a 10 and that is what I used. I didn't think the upgrade to a 13 was worth it.
    I don't think 19s exist for a 700.
  7. dyeager535
    26,982
    191
    Talk to a rebuild place, probably see what others have recommended for 700R4 parts on other forums.
    TYPICALLY performance pumps are modified in more ways than just the rotor/vanes (bigger boost valves, enlarged fluid pathways, etc) so it's worth shopping around IMO.
    I recommend these guys: http://www.700r4l60e.com/ they did me right with a bunch of 2004R parts awhile back, and speaking with the guy on the phone at the time, it was obvious he knew what he was talking about and not just hocking parts.
  8. Teamstatic2001
    Dec 24, 2005
    92
    Muskegon, MI
    Oops sorry about that I got a new laptop and the keyboard is small and the 9 is next to 0 I ment to say 10
  9. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I'd skip the 13 vane pump. When I rebuilt my 700, which was just a stock rebuild with some upgrades, I talked to several different 700 guys. The reason they went to a 13 vane pump was for more flow to control all of the solenoids and whatnot in the 4l60e's and 65e's.
    Said it would be way overkill unless you are running a transbrake or a full manual valve body in a competition rig. I spent my money elsewhere as I already had a 10 vane pump. Things like a servo, shift kit, boost valve, and an upgraded sun shell.
  10. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    thanks for the replies guys, yeah i was trying to get through this without putting to much into it... broke college student sob story... so i'm just ordering a stock rebuild kit and TC from the local parts store, but all this talk of upgrades has got me interested... like the corvette servo, the boost valve, shift kit and sun shell. what brands do yall suggest, especially on the shift kit, is b&m a decent kit?
  11. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Stuff you get from the local supply houses is the same quality as b&m.
    Usually you can piece together a shift kit if you know what you are doing, if not, or can't get the right guidance from your local supplier/rebuilder, buy a b&m. Lots cheaper for the off brand stuff. Not alot of parts in the shift kit, and a competent shop/rebuild can duplicate a shift kit without buying a kit.
    In all, I spent about $450-500 in parts for all of the above mentioned upgrades including the rebuild kit and a rebuilt converter, minus the deep b&m pan.
  12. dyeager535
    26,982
    191
    I'd suggest a TransGo shift kit over the B&M stuff, just based on my previous (now years ago) B&M experiences.
  13. Myke
    Myke Registered Member
    Sep 3, 2006
    31
    New Jersey
    Transgo
    TCI
    B&M
    Are my top 3 in that order.
  14. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    The pump in my 700 is taking a dump....would one of the mentioned pumps above be a good replacement? Also, can you replace these without much trouble....like a pull and replace type thing or do you need special tools?
  15. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I'm currious as to how you know the pump is taking a dump? My 700 is super slippery and probably only has another 1,000 miles or so in her (just added Lucas stop slip and it helped a ton but it's only a band aid) and was just wondering how you knew.
    -Avery
  16. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    I think i'm gonna go with parts from monster transmissions, pump, servo, shift kit, boost valve, and sun gear shell for $295.00 free shipping, only thing is the pump is a reman and it doesn't specify on vanes... maybe i should give them a call... any other good mods while i'm having the work done?
  17. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    bumping it back to the top just because i don't want to junk up the forum with another one of my threads... just making sure no one has any more suggestions...
  18. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    The pump seal keeps leaking after several gasket changes. I've been told by several people that if the seal continues to leak that there is a bushing in the pump that has gone bad which makes the pump housing not seal up in the tranny.
