suitable driveshaft with slip-yoke eliminated
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Sep 17, 2001.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    I have been thinking about getting a Ford or Dodge 208 case with the fixed rear yoke and swapping parts with my Chevy 208 to eliminate the slip yoke. I may as well have the big (1350?) U-joints at both ends since I will have a 14B rear end anyway. I understand that I will most likely need to have it re-tubed. With that said, does anyone know what kind of 3/4 or 1-ton truck would have a driveshaft with a good amount of slip joint to it?
    <font color=green>"It is generally not adviseable to eject directly over the area you just bombed"</font color=green>
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I think all the truck shafts will be way too long for a K-5. I'd go with a new CV shaft from High Angle Driveline.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Like Jason said you need to call Jesse at Highangle and get you a CV 1350 driveshaft like me. The only drawback is that its ahhhhhh, Pricy!!! But well worth it.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. Blue85
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    All of the local shops are telling me that a C/V is generally weaker and should be avoided (I know, opinions are like noses...). They also say that a Blazer with 6 or less inches is easy to get smooth without it. I know that I can always spend a bunch of money, but it is much more fun to be smarter and therefore afford even more upgrades.
    Like I said before, I know that it would have to be retubed and balanced, but what kind of truck shafts should work?
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Call Jesse. The man ROCKS!!! His CV shafts are NOT weak. I've got a 4" lift on mine and even after having dropped the case, I still got a little vibe. I'm saving the coin for a SYE and a new driveshaft from Jesse to get rid of ALL vibes
    Kyle
    89K5
  6. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    How much slip are you looking for? Any blazer or truck with a 203 transfer case has a slip yolk in the drive shaft. I'd say it extends/compresses at least 6".
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  7. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I have a Dodge version NP208. Came out of an '80 3/4 ton truck. If you're interested, let me know....
    Marv
