Summit AN fittings? Quality Problems???
Discussion in 'The Garage' started by loafer, Dec 14, 2006.
  1. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Has anyone noticed a quality problem with the Summit brand of AN fittings? I'm plumbing a fuel system at work and I'm finding a lot fittings that will not seal properly. When I plumbed my truck I used Russel fittings and none of them leaked, but I'm having a hard time with the Summit ones. I called Summit but they just said I could send them back and they would "inspect" then and issue a refund if they found a defect. They, of course, said they have had no complaints about their fittings. Hardly worth the effort to ship them back for $20-30 worth of fittings.
    The only thing I found in searching the web was this:
    http://www.fordmuscle.com/blog/beware-of-junk/11250
    :dunno:
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I've noticed that the fittings one particular plastic type fuel cell mfg makes for their cells are dead soft. The only thing that saves them is the anodizing. When I machine them for the various weird uses at work I have to be carefull not to tear them right out of the lathe chuck.
    Could be that you have fittings from the same source.
