Summit cams? Mine came in. . . any experience?
Discussion in 'The Garage' started by BowtieRed, Aug 22, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Well, I ordered a Summit cam and lifter kit, maybe cheap, but it should only see a few months of use. It's a 282/282 with .465 valve lift and 224/224 duration @ 0.050" pretty decent size i guess, can't wait to put it in with the carb and intake i got /forums/images/graemlins/laugh.gif thought i'd let ya'll know- has anyone ever had any experience with summit cams?
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    A friend of mine has one in his 454 that runs racing fuel and he has had no problems, his motor is built up quite a bit.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i believe they are manufactured by crane cams, but i just saw that one place, i forget where, so i guess they are probably decent.
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I have run several of them and have always been pleased.
    Marv
  5. 1-ton
    Apr 17, 2004
    2,884
    161
    Las Vegas, Nevada
    I do not know what all this talk about buying a cheap cam that will only be run for a few months because the camshaft is so cheap it will only last that long. I guarantee that if the engine is broken in properly on it initial start up, that your cheap Summit camshaft will last a couple of 100,000 miles.
    The main reason people have camshafts that only last a few months is because they screwed up something on the engine during its initial start up and break in period. Most people screw up their new engine by not putting the distributor in correctly, and they sit there cranking the engine with the starter motor over, and over, and over, and over, and over...popping and banging the engine, until the engine is completely scarred up from the pistons to the main bearings.
    This is what happens when an inexperienced "shade tree" mechanic tries to put a new engine in their vehicle.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    The reason it will only see a few months' use is because i am going full roller later on and just wanted to see some gains now. I am going to follow all instructions EXACTLY and keep it above 1500rpm and change rpm for the first 15 minutes and everything /forums/images/graemlins/laugh.gif
