Summit converter's and Kicker shocks.....opinions please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Mar 20, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Summit converter\'s and Kicker shocks.....opinions please
    Ok as much as I dont care for summit they have a 1500 stall for 90.00 and I am wondering if anyone has ran one on there K5 and or one similar, also Looking to find some kicker shocks that bolt to the leaf top plate and to the frame...where can I find some and will they help my wheel hop problem without hendering my travel to much?? THX everyone
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: Summit converter\'s and Kicker shocks.....opinions please
    Kicker shocks - had them on my first 79 - no help with wheel hop or anything but looked cool /forums/images/icons/crazy.gif. Do you have blocks in the rear?
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Never been a fan of kicker shocks - I've been working on engineering something like Autofab's 2-link for Broncos <a target="_blank" href=http://www.autofab.com/16rear.htm>http://www.autofab.com/16rear.htm</a> - Puts an end to wheelhop and doesn't have a negative effect on travel. As for Summit's torque converters, I had great luck with one on my C10 - it survived (and I'm sure it's still running) a built 396 without a complaint.
  4. twenty_below0
    May 16, 2001
    436
    That looks good but i just want the tubing that runs to the frame not all the shocks, and dont want to pay 300.00 for those 2 pieces.........THX for the converter info, what rpm did it kick in at....if you can remeber.
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I dont know about the summit converters, but I blew up a hughes 2500 stall. I though it was my tranny, so I rebuilt it and it still happened, so now I need a converter. Buts thats with NOS and I have almost 700 ft/lbs at launch on the bottle /forums/images/icons/smile.gif
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It kicked in right at 1900 RPM - More than enough for laying scratch in all 3 gears/forums/images/icons/wink.gif On the Autofab system I am/was planning to run just the bars - GM didn't leave us quite enough room for all the shock gadgetry. The whole thing's kind of moot for me at any rate right now, since I'll be sporting the ultra-groovy 67 F100 with green shag carpeting until the next project gets figured out.
  7. dyeager535
    26,979
    If you do a lot of crawling, the higher the stall speed of the converter, the harder it is going to be on your transmission. Higher stall=more heat generated, and you don't want your converter "slipping" constantly...if you spend a lot of time at low speeds, (non mud wheeling) a high stall converter is a bad idea.
  8. twenty_below0
    May 16, 2001
    436
    I will occasionally do some crawling but usually it's in the mud and or sand the river bottoms here are miles wide kind of fun to just cruise around out there looking for places to get stuck...LOL I will try the converter but will run a cooler and a fan on the cooler...our climate is fairly mild also. Still looking for the Kicker shocks ...where to buy them?? THX for all info
