Summit Heaters
Discussion in 'The Garage' started by JUNIOR-K5, Feb 1, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Has anybody ever run the summit heater thinking of getting one for heat and defrost are they good or should I go with name brand.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    JC whitney has a cheapo that I thought about getting. I just want some heat for the feet. A defrost would be nice also in times.
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Well nevermind. They arnt that cheap at all.
    I saw a heater setup in a Suzuki Sammy in the junk yard that looked pretty promising.
    The one in the FJ40 Landcruiser also looks pretty good. The hose hookups are on the side and the defrost flap is part of the unit.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also check out the rear heater from '73-91 Suburbans. It was an option, so you won't find it in every rig, but the one in my '90 throws some SERIOUS heat! The heater hoses connect straight down through the floor. You could grab the heater box, wiring and dash switch pretty cheap from the junkyard. :)
