summit's "lowering "shackle.
Discussion in 'The Garage' started by 55Willy, Aug 2, 2002.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    summit\'s \"lowering \"shackle.
    I have the ORD flip and I plan to switch the brackets from left to right and vise versa and run the furd 57's to do this I want to get the lowering shackle that summit sells to get a better angle with the shackle.
    I know I will weld the open side up to give it more strength but my question to those of you who are running it.
    does it come with bushings?
    how much longer is it?
    do you like it?
    TIA
    -Jeremy
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Re: summit\'s \"lowering \"shackle.
    I know it's not an answer for ya...but when you swap the shackle flip side-to-side, and install it in the same spot the previous stock shackle was, does that give the correct positioning for the f*rd 57" springs (with the lowering shackle you referenced)? Thanks...sorry to hijack.
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Yes that is the info that I have gathered on it.
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    They do come with the bushing installed if your talking about the Belltech #6400 lowering kit & they are about 2" longer than stock.
    Bill C /forums/images/icons/grin.gif
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    cool thanks/forums/images/icons/cool.gif
  6. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Your welcome, Just get a catalog for your year and you are set for new parts.
  7. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I've looked at the same shackle to add additional flex to my rear springs.Look at the "desert Steel" or "Steel Horse" versions.They look a bit more sturdier than the Summits.Of course if you are going to weld a piece(good idea!) in it then it really should not matter.Still waiting to see what kind of additional lift it will provide.I'm running 56" long rear springs and moved the shackle flip back 2",so at this point the shackle is at an 60 degree angle.It provides anice soft ride but loading sucks!Mike
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Thats funny. my year....oh man /forums/images/icons/laugh.gif the shackle is made for the 88 to 98 trucks and I have a 55 on a 77.
    does belltech have a site, i think summit's shackle is the exact same thing. whats the price ont he belltech??
  9. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I have a 76 use part #6400 $59.95+T&amp;S&amp;H
    Bill C
