sun super tach??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bablazer73, Jan 12, 2003.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I picked up a sun super tach 2, but I don't have directions. It has a red wire, black, white, green. red and black i assume are power/ground. green for lights? white for trigger? anybody got a clue?
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    IIRC The green is the trigger wire and the white is the lites.
  3. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    I just installed a Sun super tach in my truck.
    white=dimmer switch
    red=hot [on with iginion switch only,not acc.on also]
    black=ground
    green=tach pickup
    0n 89 tbi I wired.
    white to radio light input
    red to alternator iginition input wire
    green to white tach plug wire on coil
    black is easy any ground should do
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    great, now I have something to do today!
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I never was any good at getting the dimmer wired up by going to the headlight switch. I normally just wire it so it's lit up all the time. Someone told me you can wire the dimmer into the dimmer wire at the stereo. Should make it easier, but I've never tryed it.
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Ummm why not just put a female spade terminal on it and plug it into the fuse panel, there is a terminal for panel lights you know. /forums/images/graemlins/thumb.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Nope, didn't know that. Guess ya learn something new each day.
  8. joker89blazer
    Nov 21, 2001
    130
    There is special crimp conectors made that "hook" on to the fuse to tap the power supply.
    I don't know where to buy those at,so I tap into the wiring. /forums/images/graemlins/wink.gif
    As long as conection points are made good I don't see a problem with modifying the wiring
  9. joker89blazer
    Nov 21, 2001
    130
    That's what I did. Easy to get to wires,real easy after some low life has helped himself to your cd player already. /forums/images/graemlins/angryfire.gif
    Works good hooked to radio dimmer light input
  10. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Not the fuse itself, there are single blade terminals on the fusebox, some are BATT a couple are keyed power and one is for panel lights.
    No special connectors required, just a female spade terminal.
    I dunno if ya want to practice yer cut and splice skills then hack away.
    But on my 73,78 and 81 there is a panel light terminal that I have wired all my gages wired into.
    Maybe it is only my rigs that have these.
  11. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    BTW there is no fuse for the panel lights.
    The dash lights are on the tail light circuit.
    Just remember... if you suddenly lose yer dash lights check the tail lights, if they are out then replace the tail light fuse.
    And find out why ya blew the fuse.
  12. joker89blazer
    Nov 21, 2001
    130
    Didn't know about the spade connection points on the fuse block,must be on the backside.
    As for as making changes to the wiring..
    I service comercial laundry equipment for a living. Sometimes changes are needed to the wiring are even a complete rewire job. Working with electrical diagrams and systems to produce a safe and reliable system is something I am comfortable with.
    I agree with a concern with "hack jobs".
    I have seen some pretty bad stuff done.
    If you know what you are doing, I don't think modifying the electrical system is anymore a bad thing than modifying the drive train, bad things can be done there also /forums/images/graemlins/shocked.gif
  13. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    No not on the back, right on the front of it.
    I fix rigs for a living and have to deal with hack and splice jobs on a regular basis.
    I was on one tonight for the marker lights being out and blowing the fuse.
    What a freaking nightmare, I got disgusted with it all and just ripped out all the wiring and redone it all.
