sunfire woes
Discussion in 'The Garage' started by mostwanted, Mar 30, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    So I was doing a tuneup and brakes on my wifes car this morning. I replaced the brakes, changed the oil and filters, and attempted to change the spark plugs. All went fine all the way down to the last spark plug. The old one came out fine, but as soon as I tried to screw in my new premium plugs the dam#n alumnum threads in the head stripped out.:mad::mad: So I guess I am going to have to remove the head, drill and insert heli coils. Any suggestions?
  2. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    maybe find a larger plug with the same heat range, etc. and retap the hole for it. it's cheaper than the helicoil, and i've seen too many helicoils back out with the fastener or break, especially with parts that aren't meant to remain tightened for long periods of time, so i'm not really a fan. i don't know how often you pull your plugs, but i change my coppers about every 20K miles and pull them periodically to read them. i wouldn't trust a helicoil for my uses. my 2 cents.
  3. Currank5
    Currank5 1/2 ton status
    Apr 4, 2006
    244
    South Dakota
    www.timesert.com I asked a similar question not to long ago and another CK5 member turned me on to these. The kit is pricey but i'm sure i'll use it again, and the inserts themselves are cheap.
