Super Charger instead of Turbo Charger on 6.2L Diesel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by josephn, Nov 28, 2000.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Is it possible to use a super-charger on a diesel instead of a turbo-charger?
    Why or why not?
    Again Just curious.
    Joe
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could, but I am not sure if they make a supercharger for that app.
    You would have to check Paxton and Vortech... Or you could make you own app. by Buuying the supercharger and having the tubing and mounting brackets made if it is not available.
    Why not both though? :) We had a GMC General with an 8v92 Detroit Diesel and it had both..
    Was the 6.2 a Detroit design? Didn't GM use a Detroit Diesel for a while?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    A turbo is better because the boost it makes depends as much on the load the engine is under as it does on engine rpms. I just got a Banks turbo for my Blazer for $1150 from diesel injection severice www.dieselpage.com. As for doing both, you'd really need to beef up the engine for that. A 6.2 is probably at it's limits with the 10 psi of boost you get from a banks turbo. The Detroit motors are supercharged because they're two cycles and they need a blower for scavanging.
  4. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Well boost is dependant on intake demand and exhaust outlet. On a supercharger it depends on rpm and intake demand for psi.. Turbo's are much better on 4 cycle diesels b/c it takes very little power to spin a turbo it's just spent exhaust. But a compressor (ie. blower) uses the crank for boose which takes alot of power. Look at this for a top fuel dragster makes 4000+- hp at the flywheel the blower takes over 2000 to turn so in actuality the motor makes 6000+ hp. Maybe that puts it into perspective...
    Love, Peace, and Hair Grease...........
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Whipple makes a supercharger for the 6.5 Hummer. I read some comments from a guy who had one and he was very satisfied with it and had a lot of miles on the setup.
    SteveB
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
  7. 65FL
    65FL Registered Member
    Apr 11, 2000
    31
    Castle Rock, CO
  8. josephn
    Nov 3, 2000
    138
    Utah
    Cool Thanks Alot. :)
