super duty shock towers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, May 20, 2002.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Anyone got picks of how you set up super duty shock towers up front. It looks like steering column is right in the way. Dou you just rotate them towards the back? Are shocks still effective at that angle. Also, do you have to modify the mount on the axle. The stock mounts are angled and the ford ones are 90 degrees to frame.
    tom
    Whoa, just looked at writeup on UAV and noticed, "I,ve got a different set of towers here." I'm gonna look at this again in the morning in daylight. When I put in Dana 60 front in, I'm going to change from dual shocks to single. I guess I'll just go with the rearward position and jam the towers in there somehow. Has anyone used the "new" frd shock towers?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I've noticed on the Auto truck the shock towers are fine in the regular position (where the rivits came off just bolt the towers on like the writeup) but when i put them in mine (i have a standard tranny) the clutch "Z" bar would hit the tower so I had to rotate it a little----I dont like it in the position now but havent figured out what im gonna do---ill get some pics tomarow.
  3. flip1
    flip1 Newbie
    Oct 23, 2002
    AZ
    I just ran into the same problem with the clutch linkage. Have you figured out a solution and do you have any pics?
  4. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    I have some pictures but no place to host them. I can e-mail them if some on wants to host.
    David
  5. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Put them in members Rides.
  6. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    I will do that today, thanks.
    David
  7. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Try this [​IMG]
  8. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    There is a larger image in my Member's rides.
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
  10. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Rene,
    You are sooooooo cool!
    David
  11. grumpy
    Jan 7, 2001
    353
    San Diego, CA
  12. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Maybe I need some more practice time.
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    David..is that the F250 shock tower or off a newer Ford?
    Rene
  14. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Trusty, what year truck towers are those in the picture for and what is your extended shock length and compressed shock length ? I have been wanting to do this mod for a while but never had all the info. That looks good! /forums/images/graemlins/thumb.gif
  15. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Rene,
    Yes it is an F250 tower. I should have thought ahead and got the year info. I will check and see.
    David
  16. grumpy
    Jan 7, 2001
    353
    San Diego, CA
  17. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Those are Grumpy's shock towers...I just posted the larger pic./forums/images/graemlins/crazy.gif That mod has been on my list for a long time too...
    David, thanks. I was pretty sure they were 1980 F250 towers...I thought maybe someone had found some newer Ford crap that worked too./forums/images/graemlins/thumb.gif
    rene
  18. twenty_below0
    May 16, 2001
    436
    THX for the info MUCH needed, now could you possibly tell me if you remember, how long you think the shocks are extended and compressed. I am bidding on a set of Skyjackers as we speak that are open 30" and closed 17" but wish I knew if they were to long for the front tower design with a 4" lift..... Would really appreciate it
  19. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    You can make almost any shock fit with thoses tower by cutting them to your custom length. The shock I am using are Rancho and are 28.6/17.7. I could probably use a longer one. The only way to know for sure is to set the truck up the way you want it and flex it up. Check the compression and extension from there.
    david
  20. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Did you notice that my towers are near vertical? The UAV and others angle them rear ward.
    David
