super hesitation?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Dec 5, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    I start my truck each morning when its cold and let it run for 15-20 mins...
    well today for some reason, i get to the end of my neighborhood road, which i need to negotiate a steep but short incline to get on the main road, well i pull up and have to stop to let a car pass...
    my trucks sounds like its about to die, so i hit the gas and it doesnt move...it starts rolling backwards, i think the choke is stuck so i put it in N and rev it a couple times, put it back in D and same thing, starts to die...so i have to roll backwards a few feet, sit there and rev the engine over and over for a while, then i go to leave and its still doing it, so i have to give it gas and just hold the brake, luckily i didnt have to stop so i got out all in one motion. Seems fine after i drove it to school.
    This is making me hate carburators more and more each day.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hummm.....you did check the choks to make sure its openen fully? You could have a sticky float that may be causing it to flood. Carbs are lots of fun! /forums/images/graemlins/ears.gif
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    one of my quadrajunks juss went out...and it would not run fine in N put once u started lettin out on the clutch...you would have to floor it and around 4500 RPM it started gettin power...so i replaced the carb and now its all better. and instead of a new quadrajunk, i used an edelbrock 1406
    NITRO
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    NITRO
    I used to be the post boy for the exact swap you describe until I went fourwheeling with an Edelbrock carb.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    NITRO
  6. tecton
    Dec 1, 2002
    1,553
    WV
    im thinking about going FI
    seriously thinking about it
  7. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I had to bust ice off my choke the other night, to get my truck to run.
  8. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    You check for any vacuum leaks? Could have been a loose hose and the driving and bouncing around may have shook it back into place /forums/images/graemlins/thinking.gif
