? Super Lift Springs ?
Discussion in 'The Garage' started by TexasBlazerBoy, May 1, 2006.
  1. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Are they worth a SH!T or not. This is for a trail rig. My local guys say they can't get Tuff Country springs.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    They'll be stiffer than TC springs, because they have a higher spring rate. You can order TC springs form suspensionconnection.com and several other places.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Or get the TC's from ORD - here.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    really?
    im not being a smart ass... :crazy:
    my 6" front softride superlisfts squat to 5" with the truck weight on them... seems like they arent a higher spring rate.... really flexy too :wink1:
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm just going by what I've read. I'm a cyberwheeler :D .. I've never actually had experience with either spring :o
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    that is cool im just letting you know that my 6"ers droop to 5" with weight on them....
    standard stance of truck
    tire squatted all the way up and could go more if my cab wasnt in the way
    my shocks stop me from flexing down more.. if I did though my front d-shaft would seperate!!!!! need a front shaft with longer splines!!!!!
    redneck driveway flexin...
    look at the frame flex!!!!!
  7. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Friend has superlift on springs on his CJ-7. They flex pretty well but hitting train tracks hurts, usually his rear end jumps out to the side:eek1: They dont do high speed stuff well imo, they tend to bounce. Hes also using superlift shocks.
  8. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I've never used TC springs, but I have 4" Superlift springs and they are soft enough for me.
  9. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I believe they make 2 different spring rates.
    The HD one are stifffer than the normal ones.
    I would like to try a set of the TC's to compare, My SL HD's are fairly stiff
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    You dont know the differance between superlifts and tc's until youve tried tc's Once you get a set of em, youll never go back (unless your running a custom spring :D) Also a tc 4" spring has more free arch than a superlift meaning that it gets its height from arch, not spring rate. this means the spring can be soft but still provide lift.;)
