super lift
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by the hulk, Aug 24, 2003.
  1. the hulk
    the hulk Registered Member
    Feb 9, 2003
    40
    phx az
    hello everyone
    i got a 6 lift from super lift front and rear springs and from talking to some freinds im not sure if getting the rear springs was a good idea thay say i wont get good travel out of the there to stiff. has anyone one installed this lift befor and dose it work well or did i just biuld a bucking board
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The springs will be stiffer than the factory springs.
    Maybe that is what you are looking for (less axle wrap, more load carring ability, etc...).
    I like using a shackle flip in the rear to keep flater and softer springs out back. If you went with a Ecobit you could use your stock springs and some small blocks to level out the rear. Or a ORD shackle flip and some taller blocks or some 2.5" lift rear springs.
