super low range np203
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Sep 3, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    hey guys,
    my 203 just crapped out, Seems like I heard about a 3.6 to 1 ratio low range 203. Has anybody bought one of these and where do you get them at. If I don;t get one of those is anybody running dual transfer cases, 203 and 205. Any help would be greatly appreciated
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    There is a lot of guys on here running double t-cases. Offroad design sells a kit for putting together your own doubler. ORD
  3. 76K5
    Jun 23, 2001
    99
    North Carolina
    cool, I am guessing the t case is toast. Every time in 4 lo with hubs locked and a heavy load transfer case starts popping and the rears will spin and the fronts only spin a little bit. Sounds like chain is slipping? Does this sound right?
  4. Calclips
    Apr 4, 2001
    1,005
    I'm not sure, I don't really know anything about 203s... sorry /forums/images/icons/confused.gif
  5. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    It definitely sounds like you have chain problems. The 203 low gear sets are available from www.wagonermachine.com . As for the dual transfer case set up do a search for "doubler" you'll find a ton of info, a lot of guys here run them.
  6. 76K5
    Jun 23, 2001
    99
    North Carolina
    thanks, one more thing, it seems like I remember seeing an add for a np203 that was a single unit that was 3.6 to 1 low range. Anybody know where to get one?
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    wagoneer machine does the low gearing in the 203. but the cost of them to do it you might as well buy a cheap 203, or see if your gear box is good on YOUR 203 and get the parts for a Doubler from off road design.(www.offroaddesign.com)
    a lot of folks have the doubler. i plan on running a divorced doubler so i can equal out my drive shaft lengths.
    grant
