Super Swamper Iroks causing vibrations
Discussion in 'The Garage' started by PROFESSORSK5, Sep 16, 2004.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    I got a brand new set if 36x13.50x16.5 Iroks last week. When I get my K5 up to about 55 Mph it starts to vibrate and bounce and continues until about 70 Mph. Has anybody had this problem and how did you fix it. /forums/images/graemlins/k5.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    did u get them balanced? or sometimes if they sit for a while they will get flat spots but even out after some driving
    Did u have big tires before? If not the bigger tires tend to make samller front end problems show up
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    theyre out of round, maybe just slightly but a lot of swampers are. one thing a ton of guys do is put about 10oz of BBs in each tire they help balance it at higher speed.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Welcome to the club. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Be proud. /forums/images/graemlins/thumb.gif
  5. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    my 39 IROKS don't vibrate one bit, unless i hit a little pot hole or bump at low speeds then i get the death wobble. I haven't gone more than 70mph or so in them cuz it get's scary after that but you should have them re balanced, i haven't had any flat spots with them either and i've let it sit for a week, and yea there the ploy's not the radials.
  6. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    I had them re balanced and that didn't help. In fact when they balanced them the drivers side rear was wobbling on the balance machine and we looked at the rim and it was true. Also the problem is in the rear of the truck not the front. The front two tires are not a problem in fact it handles real good. /forums/images/graemlins/k5.gif
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    You could try replacing or adding a steering stabilzer on the front. I'm assuming you also have the stock front axle??
