SUPER SWAMPER TSL vs. TSL SX
Discussion in 'The Garage' started by jacked_86chevyk10, Feb 20, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    whats the differnce in tsl- radials and tsl-sx? i dont want the bias but whats the differnce in these two? thanks fellas
    /forums/images/graemlins/peace.gif
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    TSL SX is bias ply, and may have some fiberglass belting.
    It is not a Radial tire. It has some sidewall lugs(tread).
    The TSL Radial, is a Radial tire with steel belts.
    It has the ever so popular 2 ply sidewall construction,
    which in my opinon is very, very weak(by Design).
  3. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    And also the bias TSLs will probably conform better at low pressures but are prone to flat spotting while parked for awhile. Mine take about 5-10 minutes to smooth out after parking overnight. The radials may be a better choice if you do a lot of street driving.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The SX is an extremely tough bias swamper, the sidewalls are very thick and strong. It conforms very well to rocks and rough terrain but gives a very stiff rough ride on the road and wears just as fast or faster than boggers and TSL's.
    The TSL radial is a nice tire for someone that is going to be on the street a fair amount of the time. The tire lasts for a lot longer than the bias version. The only thing I don't like about the radial TSL is that the tread width is narrow on those tires compared to the carcas width.
