Supercharged blower motor?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by transcore1, Apr 21, 2003.
  1. transcore1
    transcore1 Registered Member
    Aug 15, 2002
    44
    Anyone know how to increase the volume of air discharge at vents with a/c. I just went all the way through my a/c and heat with new everything and it blows like a reluctant Monica Lewinsky. It is getting cold and the blower resistor is OK. It just does not put out enough air volume for a hot Florida day. It is working properly but I would like to increase the air flow past stock if it is possible. I have sealed the blower box to the firewall and disconnected the heater core.
    Transcore 1
    89' K5
  2. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    You probably either have crap clogging the ducts, or more likely, a flap or door somewhere in the vent system is either not closing tight enough or not opening up enough. Also, you might want to crack open the AC core housing and make sure the core isn't packed with old leaves and bird's nests.
  3. transcore1
    Aug 15, 2002
    44
    Everything is new or like new and I completely removed the system and re-installed it. All doors and vents operate as new.
    New evap/dryer/condenser/controls/blower/compressor/motor resistor/etc. It just doesn't come out like a new truck....
    Scott
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    When it is on "max" does it recirculate or does it still suck air from outside?
    If you switched to R134a keep in mind it's not going to be nearly as cold. R134a works at a much higher temperature than R12. You aren't going to be able to get the system to below 38° like you can with R12.
  5. transcore1
    Aug 15, 2002
    44
    Sorry I didn't add that I charged with r-12 per specs. I think it was 3.25 pounds. It's ice cold, it just kind of falls out of the vents. My late model suburban will freeze you out. I just need too increase the air volume with a faster blower. I just don't know what woould work.
    Scott
  6. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I was thinking of trying a newer model fan motor, or maybe just the fan itself. I'm not sure but it seem like the newer style fans must have more pitch or something. /forums/images/graemlins/usaflag.gif
  7. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    OK, get a fan motor for a Suburban with air conditioning or a fan for a Canadian vehicle. They have high-rpm fan motors. They can be spotted by having the rubber tube that goes from the box to the back of the motor. Auto parts stores should have these but you might be better off going junkyarding. If you go junkyarding take a pair of leads with alligator clips on them and hook the fan to your battery to see how fast it spins. If it sounds like its spinning faster than yours then get it.
    Next, go to the junkyard and find the deepest depth and largest pitch squirrel cage that'll fit in your vehicle. Usually Suburbans or plow-package pickups with AC had these giant ones. I don't know about K5s. These are hard to find new and when you do find them new they're usually the standard ones that go in non-AC vehicles.
    By the way, you have tried applying 12v directly to the fan motor (no switch, no coils) and it still didn't move enough air, right?
  8. transcore1
    Aug 15, 2002
    44
    Yes, I did play with direct wire. I also taped all the seams in the ductwork and selaed every seam on the airbox. I am going to the u-pull-it yard this weekend and I will look at different squireel cages and see if I can spot a difference. Also look for a fan with the cooling tube.
    Thanks for the input.
    Scott
  9. chevy4x4boy
    chevy4x4boy Registered Member
    Feb 19, 2003
    27
    elizabethtown, pa
    yea i'm lucky enough to have one of these coveted canadian blower motors and let me tell you this thing will blow some air!!! too bad my a/c isn't charged but it will be in about a month when the weather around here starts getting hot enough. i hope you are lucky enough to get one of these and good luck going to the junkyard!!
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  10. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    I put my ac in myself and made sure to seal everything up. And I guess scince I live in Canada I have the Canadian blower motor, all I know is the motor came from a 89 suburban(the rest of the ac is from an 80). But this thing will blow my girlfriends hair back when its on max. It is strong. I never use it on high for heat or def. 3 blows strong enough. I'm glad to find this out cause I hope my a/c blows ice cold when filled.
    /forums/images/graemlins/grin.gifThanks for the info all
    Steve
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think Chevy Duty sells heavy duty fans's and motors
  12. dyeager535
    26,980
    There are two blower motors. Non-AC, and AC/Heavy duty heater option. So if you have AC, you have the "strongest" fan motor you could get.
    The squirrel cage is the only difference between the HD heater setup and AC, since the AC box/HD heater box is what determines how "deep" the squirrel cage can be, and the HD heater box is only as deep as the standard non-AC box.
  13. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    hook two 12v batterys in series and attach to the fan power supply and your blower wll blow your socks off(on floor position) /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
