Superduty shock tower nuts
Discussion in 'The Garage' started by sandawgk5, Feb 18, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am getting ready to install the superduty towers up front and need to know what size the nut is for the shock tab. I thought it was 1/2-13 but it does not fit is it metric? Also the upper shock mount on the passenger rear stripped does anyone know how I go about getting another one of those other than a junkyard?
    Ira
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If you're talking about the stock bolts/nuts for the SD towers, I'm almost 100% sure they're metric. The locking nut feature is nice, but if one is shot, why not just use a grade 8 from the hardware store? Finding another ford lock nut may be difficult, unless you are willing to spring a couple of $$ at the stealership.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    no such thing as metric grade 8, they have equivalents but not grade 8. it is a metric nut for sure but i dont remember the size.
  4. sandawgk5
    Oct 28, 2003
    6,881
    Ya I intend to buy two nuts for the upper shock stud. That is the nut size I need I already have nuts and bolts to bolt the mount to the frame. I would just prefer to not carry the mount into Lowe's when I go to get them but it might be my only choice.
    Ira
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Just sell me the towers and be done with it
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I didn't think the nut was a metric. I rummaged around in my spare parts and found some locking nuts that I used. My LMC catalog also used to have the rear shock post bolt listed. I don't see it now, but I've seen them in auto parts stores. I may even have one laying about, I'll look.
  7. sandawgk5
    Oct 28, 2003
    6,881
    Nice try:D.
    I am thinking it is metric cause I used my thread pitch gauge and it was 14 TPI and the SAE 1/2 is 1/2-13. I found it kind of odd. Appreciate the help and any info you can find.
    Ira
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I don't remember what designation they are but they're metric. I messed around in the hardware store for 45 minutes before it dawned on me that the might not be SAE.
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I'll take one of mine to work tomorrow and spec the stud out and report back.
  10. sandawgk5
    Oct 28, 2003
    6,881
    Kewl thanks
    I will prolly be mounting mine tomorrow or Tuesday. My shocks should be here on Tuesday also:D .
    Ira
  11. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    While this may be technically true, there are corresponding higher grades for metric nuts and bolts. As I re-read the original post, know I see he referred to the shock tab, and not the mount bolts, which was what I was speaking to.
  12. Stomper
    May 11, 2002
    3,767
    Iowa
    M12x1.75
  13. sandawgk5
    Oct 28, 2003
    6,881
    Thank you very much sir, I will go pick some up today:D .
    Ira
