Superift Brakelines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Aug 20, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I just tried to install their SS brakelines and the fronts are different from the stock set up. The end that goes through the frame doesn't have a grove in it to slide the c-clip in. How are you supposed to tighten it up through the frame cuz the hose gets pulled right through the frame hole? I could use a washer or grind down a bid nut (flat) and tighten against that I suppose. What do you guys think?
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Sorry can't help you. I just got the Skyjacker SS lines and they were a perfect fit....Dan
    If it ain't broke.......Don't fix it....
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    My Superlift lines came with a very thick Snap ring that was supposed to be clamped on the rear(frame side) of the brake line fitting. The thing was so thick I couldn't get it to budge. So instead i used a nut since the brake line fitting was threaded. Works like a charm!
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
