superior axle vs. warn
Discussion in 'The Garage' started by Jonny-K5, Nov 29, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    does anyone know which axle is stronger? both are $99 axles, nonchromoly. vender on 4x4 pirate said the warns are 30% stronger than stock, are the superiors the same? better? worse? they r for a rear 10b. and lets try to keep the " dont waste your money" posts to a minimum. /forums/images/graemlins/grin.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What's wrong with the stock ones?
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    How much are the chromoly ones? If I was going to buy shafts I would buy the Chromoly ones instead of the stock replacement ones.
    I would say buy what ever shafts you desire, they are probably the same strength.
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I looked at both of those when I was building my old 12 bolt and ended up buying Moser axles.It has been a few years so I dont remember all the details that made them better but you can call or email them.
    Do you break axles now?If ya dont,I would just buy stock spares.If you are breaking stuff now chances are you will break an after market stock replacement too /forums/images/graemlins/grin.gif
  5. Grim-Reaper
    7,385
    Atlanta
    What I want to know is if the bearing surface is harder. My Detroit has cause the bearing surface to become galled. This happend with the Detroit in two different axle housings and 4 different axle shafts. (I thought the housing that the detroit was in when I bought it was warped and caused this so I moved it into my housing that was doing fine) I have to replace my shafts as a result.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Hmm, maybe I should pull mine and check them. Same 20yr old shafts in the back that I started with. 1 yr w/ an EZ and a couple more w/ the Detroit.
