Superlift drive shaft extension
Discussion in 'The Garage' started by CHEVY 4WD, Jul 19, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    anyone ever use one? I dont need my drive shaft to be much longer and this spacer gives 1" sposibly I havent had good experences with superlift but might be worth giving them another shot
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    that thing will work. there was one on my last rig i bought. i strongly recommend not using it & spending the green$ to have your shaft lengthened by a driveline shop. it is the only right way to fix it.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    If you have a flange style front drive output on your transfer case you can use this extension. It is 1 inch thick and is used for the front driveshaft if it uses a flange. I have one on my truck and it works out great. It is solid metal and is very beefy. My u joints/or driveshaft would break way before this thing would even think about it. It worked well for my 6 inch front springs.
    Blake
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    its a 84 ½ton 208 I do want to get my shafts lengthend but right now im at 4in and the front is just BARLEY long enough theres plans for 6in in about a year(mabe sooner) so I dont really wanna do new shafts yet
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    that spacer would be perfect..no need for over 100$ in driveshaft work when a 20 dollar piece will suffice..
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have used a few of them and so have my friends and they work great. No problems from any of ours!!! I recommend them...
  7. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    After what height lift does a longer driveshaft/extension become necessary? I'm looking to lift my '73 4-6" and this thread has got me thinking I may be forgetting some important factors to consider.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    does anyone have any pix of them? and know of a good place to to buy one? the only place i know of is TYRES and i would rather not get it from them
  9. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    [​IMG] Here's a picture of mine. Its the spacer to the right of the transfer case flange. It's 1 inch thick. I'm using it with a 6 inch lift and it works fine. I'm not sure where the best place to get it is, I got mine from the local 4x4 shop.
