Superlift front spring?
Discussion in 'The Garage' started by scooter122983, Oct 20, 2006.
  1. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    Is it possible to take off the bottom spring leafs on my front springs to achieve a lower spring rate, and then put zero-rates in to fill the void, or would i be able to do it without the zero-rates? Or would I be better off buying softer springs.
  2. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    I removed the lower two leafs off my 6-inch Superlifts, and they ride much smoother now. I did have to pick up some shorter center bolts since I didn't use zero-rates though, and a new set of u-bolts since the old ones' threads were damaged from being pressed against the springs/axles.
  3. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    i removed leaves out of packs numerous times for people. I also grease them with a heavy duty marine application style grease to help reduce friciton (and make stuff stick to them). It does work and there wasn't really a difference in lift odd enough.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i have superlift softride 6" front leafs... they are so soft that the leafs actually sit at 5" on the truck... then my ord zero rates put me back at 6" :crazy:
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Did that to the 12" fronts I once had on my 89. Took the bottom two out, lowered it some and actually made the suspesion move!!!
