superlift springs?
Discussion in 'The Garage' started by shaun89, Dec 15, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i have 6" superlift springs on my truck, the rear is driving cock eyed...i measured from the spring top plate to the front bolt on the spring and its 1 1/2" longer on the right side...its 29" on the left and 31.5" on the right....is the center pin offset on superlift rear springs?:confused:
    ps...sorry,i might have posted this before
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Lets see, 52" springs, 31.5 on one side and 29 on the other. 29 plus 31.5 is pretty dang close to 52 don't you say?
    You have right side spring on backwards. And being that 6" superlift springs have the shims built in you have some nasty bending going on under that rig that will ruin those springs real quick like if you don't fix it.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I've heard of the shims getting turned, so it's always a good idea to measure before install. 29+31=60,
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You can't put a 52" spring on backwards. The center pins are centered. I bet one or both of yours are broken. Take the spring plates off one at a time and lower the axle to inspect.
  5. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    ok cool, thanks a lot for the help guys:bow:
