Superlift SUP-1104 Question
Discussion in 'The Garage' started by cegusman, Aug 6, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Is the Superlift SUP-1104 pitman arm tapered for the one ton ends?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    One ton ends are no different than 1/2 or 3/4 ton ends, when you are referring to the drag link or tie rods.
    I have the Superlift #1104 arm and its the same size and taper as my ORD crossover arm. /forums/images/graemlins/wink.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    im running that Sup# 1104 pitman, and i had to have my buddy Make the taper bigger for the draglink ends, so i could get the cotter pin in there.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I used the same TRE's on my draglink as I did on the tie rod. They are ES2011R and ES2027L if I remember correctly.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You did not need to retaper it then?
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i used the stock draglink ends that came on the stock steering.... i think he may have used Tie rod ends...
  7. Mudzer
    3,639
    Missouri
    Nope, they worked just fine. /forums/images/graemlins/thumb.gif
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  9. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    So no reamer nessesary eh...
    I got a 78-79 ford f150 arm (they work, little spline mod) but found I have to ream the little bugger. I have the reamer, but its under locked door, not availible to me at the present time...
    6" of lift + crossover, do you think the arm is nessesary? The stock ford one seems to drop about 1.5"
