superlift tru-speed
Discussion in 'Free | Trade | Misc.' started by ryan22re, Feb 17, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    checking interest.
    used in an 05 gmc, but was taken out when hypertec power programmer was purchased. will fit anything with vss signal. with instructions.
    offers?
    *edit* talked with superlift, and it only fits 92-05 (maybe 06 trucks too). will not work on 88-91 blazers.
    $40 shipped to your door
  2. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Question: I have an 01' D-Max that I have 33"s on.The truck has a limiter that stops it at 98mph, with the 33"s I'm 11% off so I'm close to 110mph. If I put this on will it prevent me from getting to 110mph? I'd like my speedo to be accurate but don't want to loose the extra 12mph because that will make me loose to Dodges :o .
  3. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    No it won't help you with the motor turning off at 98. The truspeeds only change speedo readings not the output from the vssb to you ecm. That is there one downfall.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    second that. it will only adjust the speedo, not the actual speed limit. best bet is to buy an aftermarket programer
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    hows $50 shipped to your door?
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    bumpity bump
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Would it work in a 91 Blazer?
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i dont see why not.
    let me dig out the instructions and/or call super lift.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    ha! im retarded. will not work on 91 blazers.
    in my original post i should have said vssb. not vss. just checked the instructions and called superlift. no dice.
    is superlift part # 33003. says it fits all gms from 92-05.
    sorry bout that.
  10. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
  11. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    x2 :D
