Superlift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Apr 6, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Does anyone here have a Superlift kit? I am looking at the 6" kit with front and rear springs. How is the ride quality? What else needs to be done besdies lowering the transfer case and extending the brake lines? I will be running 35's Tahnks
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I ran Superlift's Superride on my old one and loved it - it was as close to custom springs' characteristics as I could get in a commercial kit that I was able to test.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have an 89 blazer with a 6" superlift spring. I chose to run the heavy duty front springs in mine. The truck rides a little stiffer in front but not bad at all. I used a 4" rear spring and 3" block to give it a slight rake, I hate when the rear sags. By the way, the HD front springs are way cheaper than the regular superlift springs.
