Sure wanted to use a pun for this...
Discussion in 'The Garage' started by fireplug, Dec 13, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I need to replace my blower moter, is there a higher cfm design available?
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Try the 90ish model GM trucks.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    I believe that the highest CFM rating fan was installed in 89 extended cab pickups :)
    I know the one in my truck moved a crapload of air!
  4. diesel4me
    Jul 24, 2003
    17,540
    928
    Massachussetts
    get one with A/C...
    A blower motor from a similar truck with A/C has a higher output,wider blower wheel and a permanent magnet motor that runs at higher RPM's than a "standard" non-A/C vehicle uses..those have motors with copper field coils and a narower blower wheel..but the blower wheel on the A/C motor may not fit in a non-A/C heater box,you'll have to swap the old blower wheel onto it if that is the case...
    I've used heater blowers out of Mopars in GM trucks..the Dodge trucks and even K-cars have blower motors that run at much higher speeds than the GM ones..they are not a bolt in though,some fenagling is required!..one truck I had I tried adapting a radiator electric fan motor into,that thing blew so much air it cooled off the heat!-was actually TOO fast!..worked great on medium and low speed,but high speed was too much..I could have used it for a leafblower!..:eek1:
    I've seen "Heavy Duty" blower motors in the J.C. Whitney catalog,and they are the permanent magnet style--also in "Four Seasons" brand,made by Blue Streak who also sell "Standard" ignition products....also,Chevy vans with A/C and a "heavy duty heater" option had beefy blower motors too..:crazy:
  5. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Thanks for all the responses. For future reference. I tried switching a motor from an '89 Burb into my '76 Blazer and as menioned the box wasn't deep enough. Even switching the fans didn't help. I'll see what I can find at the parts store this afternoon.
  6. dyeager535
    26,976
    Just go get the one for a truck equipped with the heavy duty heater option. I was a bit upset at a counter person telling me there was no such animal (since I have it on my truck and installed the HD heater myself) but was able to find someplace (Napa perhaps) that would sell me one.
    They look just like the AC motors, as they have a vent hole in the outer case. As noted, the AC plastic fan blades (hamster wheel? lol) will NOT fit in a non-AC application. They are "longer" than the non-AC/HD heater boxes will accept. You need to swap the plastic fan, there is no way around that. The motor still spins much faster than the standard ones.
    I'm not certain the AC fan motors are any different than the HD heater blower motor, but they will bolt to a non HD/AC box, this much I know.
  7. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    GREAT, thanks! You wouldn't happen to have a part number? I'm sure you would've posted it but...
  8. dyeager535
    26,976
    You'll have to check the RPO's out somewhere, I suspect "C42" is HD heater, but it could be "C41". I'll post both:
    22020945 is the C42 blower motor. Same part # as the AC blower motor, therefore I'd say C42 is HD. Check an RPO page to make sure though.
    22048573 is the C41 blower motor.
    3037550 is the C42 plastic fan. I was mistaken in thinking they were the same HD and non-HD, apparently something is different, although the non-HD fan will fit I suspect.
    3027031 is the C41 plastic fan.
    Those are all pretty old part numbers (1988) so if they don't work, you can always have them checked against changes.
  9. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    You rock!
    Ok I double checked, the C42 is indeed the HD blower, which apparently was not available with RPO C66 (A/C). Just some info for anyone searching in the future.
  10. dyeager535
    26,976
    Wasn't available because the motors are the same, thus no need. Motors spin the same RPM, AC just moves more air because the plastic fan is larger. :)
  11. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    tryin to revive an old thread here....my silverado with a/c is barely blowing anything even on high....would the c42 do me right??? anybody done this????
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I would take it apart and see if there are leaves or something blocking airflow.
  13. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yeah troubleshoot for sure. Little air flow at all is not a usual symptom.
  14. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Well it took me nearly a year to get around to this LOL but I just finally installed it. And holy mother Mary that baby blows, Blows, BLOWS!
    I never did change the air box housing thing, as the yards here are picked dry. I used the larger hamster wheel as well, as it is significantly larger than the smaller.
    I built up the height of the box off the firewall using faucet packing (big thick washers) and filled in the gap with thick weather stripping. It looks clean and like I said works like crazy!
    I also cleaned all electric connections and used dialectric grease to prevent further corrosion.
  15. dyeager535
    26,976
    You know, when I was attempting to use the larger fan, I cut a thick sheet of plastic in the shape of a spacer, then realized that if I used the larger fan, with a spacer, the portion that extended out of the box wasn't pulling any air, since it's running against the spacer. :)
    Regardless, pretty amazing how much better those motors work eh?
  16. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Hmmm I'm not picturing what you mean.
  17. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    sounds like he means the adapter/spacer he made obstructs the air movement of part of the fan, since the original hole was never intended for one that big.
    when i tested my 1994, the actual output was only 96% of a crapload, since it doesn't run at 100% efficiency. i don't know why we don't just measure in "buttloads". i guess it's because nobody wants to switch to metric. :haha:
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    83 K5 Silverado , 93 K2500 , 99 Suburban , all with A/C .
    I own all 3 , and the fan blade is the same number stamped on each one .
    83 and 93 appear to be nearly the same motor , the 99 has nice little sleeves and bushings on each screw spot for vibration dampening .
  19. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    I think you have your units wrong Vortec, I always thought "load" was the unit and "crap" was just the prefix.
    1 buttload = 10 craploads
    1 sh*tload = 10 buttloads = 100 craploads
    But maybe that is all a load of crap.
  20. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Thanks for clearing that up :rotfl:
