Surface rust removal?
Discussion in 'The Garage' started by Citizen Rider, Jan 3, 2007.
  1. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Back when i did my 1 ton swap, i purchased DIY spring purchases and plates, new ubolts, moved the front spring shackle, and my rims are rusting through the paint.
    Everything but the rims are unpainted and the guy that was working on my truck left the truck outside instead of in a shop...Leading to lots of surface rust.
    Is there anything i can put on these, or dip the parts in to remove the rust?
    Also, What can i do to the rims, since they are mounted to 38's making them alil hard to sandblast.
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I'd hit 'em with a polishing media in the sand blaster. Should do the trick. A medium steel wool works well too. Then paint them!:D
  3. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    you bring it over here and i/we will get em cleaned and ready for paint 4 ya
    you didn't loose my # right?
