surface rust removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Sep 9, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok on chrome, what is the best way to remove surface rust?
    is there a certain stuff to use?
    thanks
    <a target="_blank" href=http://confederate9.coloradok5.com/>confederate9.coloradok5.com/</a>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Coke [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    <a target="_blank" href=http://www.slydawg.rockcrawler.com>www.slydawg.rockcrawler.com</a>
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yeah Coke works well... but you should use a bit of foil when scrubbing it.. the combo, which I don't understand why works well! You can get some plain old cheap tooth paste and use it too. It's got a small enough grit that it won't harm the finish. I use Turtle Wax chrome polish. It supposed to be the type that takes off the rust. It does work well with a lot of muscle put into it. You can use steel wool too... but make sure it's like number 000 so it won't scratch it up. Of course even with this stuff be careful... I bought Rust Cutter or whatever it's called. Um, maybe I used it wrong... it sucked! Hope this helps... [​IMG]
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    SOS pads, works like nothing else.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  5. CK5
    May 19, 1999
    21,622
    701
    CO
    Hey, I have a little surface rust over my rear wheel well, any sugestions?
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  6. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I just power washed down my Blazer... holy begebies... talk about knocking off anything and everything. I had some surface rust on my leafs where some mud was caked and it's gone... I can't believe how well it works.... if you have a washer or know someone that does use it...
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I assume the rust over the wheel well is not on any crome.[​IMG] I would suggest getting it fixed now before it turns into a hole. Make sure you get all the rust out or it will come back in no time. I would use a brass wire wheel on a drill or very carefull sandblast to make sure all the rust is out of the little pitts in the metal. Then feather out the paint edge and use some good primer and paint. Or you can just whip out your favorite tool (sawzall) and say goodby to it forever.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  8. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Get some metal polish (the wadding type) you can find it at truck stops and some parts places. The stuff works great, unless you're talking major rust.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I second what Wayne said.
    As a quick fix, I usually yank any trim around the rust spot, sand it down and some surrounding paint, then spray bedliner over it and put the trim back on. Someday I'll actually so a paint job... Also helps to have a black finish if you go the bedliner route...
    Steph, I powerwash mine every now and then, and each time I lose a little more paint! Friggin '88 paint that doesn't stick to the primer, or nice chunks from small rust spots enlarging...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
