surging and faulty acceleration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sorryofficer, Jun 23, 2002.
  1. sorryofficer
    sorryofficer Registered Member
    Jun 23, 2002
    18
    arizona
    i have a 1987 jimmy and i just rebuilt the engine about 2 weeks ago...it doesnt accelerate very well and sometimes i feel it surging. Anyone have some ideas?
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Oh boy, tons of stuff here... Did you rebuild it yourself? Check for vac leaks, a little WD-40 in suspect areas should do the trick (it will change the idle). Watch the throttle blades with it running to be sure they are both getting wet. Did you set the valves. Take off a valve cover and fire it up. Take a 3/8" drive 5/8" socket and hit every rocker arm. You back the nut off until you hear a ticking because its too lose. Then you slowly tighethen it until the ticking stops, then do one half turn beyond that. It will get messy when things get warm, so work fast. A can of brake cleaner should do an excellent job of cleaning up the mess. Did you time it correctly? On the harness of wiring comming out of the fuse panel will be one lonely tan wire with a black stripe that is on the outside of the harness. Make sure that is disconnected when timing it to 0 degrees. Turn the engine off and plug it back in when done.
  3. sorryofficer
    Jun 23, 2002
    18
    arizona
    what are some suspect areas like where would you start?
  4. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Take the WD-40, carb cleaner, brake cleaner, or the like and spray it around where the throttle body bolts to the intake, along the sides where the intake bolts to the heads. Check EVERY vac line too, be sure to compare it against the sticker on the front clip.
  5. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    did you do any performance mod's to the engine when it was rebuilt?????
    also check you're fuel pressure to make sure you don't have a weak pump. might have been good enough to run you're old tired engine, but now with fresh engine with more power isn't enough.
    just my thought's, lot's of area's to check...
    dave
