Surplus center ram......???
Discussion in 'The Garage' started by stallion85, Apr 5, 2007.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hey guys I am about to install my hydro assist finally and have a few questions about the ram. It has the ends like Kid Jethros and the one end needs to be cut and re welded. How did you all cut and re weld this piece?
    Also the end attached to the piston rod, does it move? What I mean is, does it spin around in the cylinder? I can't get it to budge and I have only heard of folks having to cut and turn the one end.
    Also, I have read somewhere since it does not use heims that you have to be careful when you setup the mounts, due to the movement of the tie rod.
    Thanks for any help......I hope to start this next weekend:D
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I used a cutoff wheel on a grinder, and cut the tube off of the end of the ram body, then turned 90 degrees, squared up, rewelded. Yes, the shaft turns inside the body.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
