Surplus Of Voltage
Discussion in 'The Garage' started by cojnit, Oct 9, 2002.
  1. cojnit
    cojnit 1/2 ton status
    Jul 23, 2002
    178
    Hawthone, CA
    Some one please help!?
    Trust me I searched the forums for an answer, and could find a straight one.
    My voltage reads fine before start-up, and then it goes through the roof while running. I am blowing fuses all over the place! The Blinkers, Radio, CB Radio, all blown. The truck still runs great, but I have no blinkers.etc. I have replacved the Blinker fuse 2 or 3 times already with even higher than recommended ratings.
    This is a fairly new alternator, and I had the battery tested. Is there something they could have missed? What Am i missing??????
    Trying to get the truck running for the Big Dawg Safari next week and could sure use the help!
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Voltage regulator in the alternator is probably bad. What is the voltage reading after you start it?
  3. cojnit
    Jul 23, 2002
    178
    Hawthone, CA
    almost pegged near the 18V area. Seriously RED
  4. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Most likely the regulator. Local parts store can check the
    alternator out for you.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yep, the regulator. If they wont waarenty it, You can buy just the regulator and put it in.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Voltage regulator. Im almost 100% positive. GM style voltage regulators are internal. Well, the newer ones anyways. If its new, I'd bring it in for a warranty exchange. Nuttin you can do but change the alternator, unless you feel like ripping the alternator apart. Then its like a 5 dollar part. But like someone else said, you can also buy an external voltage regulator. (I think it might be a ford part!)
  7. cojnit
    Jul 23, 2002
    178
    Hawthone, CA
    this is on a 1976 3/4 ton. Same rules apply??
  8. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Yep. Same rules. Replace the alternator.
